Home PageI think I updated the info, but the link may not be updated...
Tailshift Transmission Adjustments
Aligning the shift rod. I spent a great deal of time aligning my shift rod
on my 914/6, which is an original tail shifter. The best way to align the
shifter is to put the car in 2nd gear, then align the shifter so that 2nd
gear is selected when shifter is riding up against the lockout plate with no
pressure. This gives you a "slot" for 2nd and 3rd. 1st and reverse will then
require a significant effort against the lockout springs to select.
1st - replace all shift bushings. Don't forget the firewall bushing.
Disconnect the shifter in the passenger compartment and inspect the lockout
plate. If it does not look like this, replace it. Note, the picture is
inverted, you'll be looking from the other side.
Under the car, select 2nd gear (Shift selector on the transmission in the
middle and rotated toward the front of the car). Now, clamp the shift-rod
into place with a pair of vise-grips.
Loosen the Bolt under the center cushion, in the passenger compartment.
Adjust the forward/backward position of 2nd so that it is in a comfortable
spot, but not too far back. Adjust the selector side to side so that it
touches the lockout plate without pressure, now move it off the lockout
plate just a hair (to the right). Lock the shaft down by tightening the
Bolt.
Remove the vise-grips. Shift it into 3rd. If it's too far forward, loosen
and slide the shift selector back. Repeat the 3rd and 2nd alignment until it
where you want it forward and back.
Once you have it set, disconnect the shift rod for the last time and
reinstall the cover. Grease everything with a high-temperature grease.
Side Shift:
Aligning the shift rod. I spent a great deal of time aligning my shift rod on my 914/6, which is an original tail shifter. The best way to align the shifter is to put the car in 3nd gear, then align the shifter so that 3nd gear is selected when shifter is riding up against the lockout plate with no pressure. This gives you a "slot" for 2nd and 3rd. 1st and reverse will then require a significant effort against the lockout springs to select.
Disconnect the shifter in the passenger compartment and inspect the lockout plate. If it does not look like this, replace it. Note, the picture is inverted, you'll be looking from the other side.
Under the car, select 3nd gear (Shift selector on the transmission in the middle and rotated toward the front of the car). Now, clamp the shift-rod into place with a pair of vise-grips.
Loosen the Bolt under the gear selector in the passenger compartment. Adjust the forward/backward position of 3rd so that it is in a comfortable spot, but not too far back. Adjust the selector side to side so that it touches the lockout plate without pressure. Now move it off the lockout plate a hair (to the right). Lock the shaft down by tightening the Bolt.
Remove the vise-grips. Shift it into 2nd. If it’s too far forward, loosen and slide the shift selector back. Repeat the above alignment until its where you want it forward and back.
Once you have it set, disconnect the shift rod for the last time and reinstall the cover. Grease everything with a high-temperature grease.
Happy shifting,
James
