John
Jun 27 2006, 11:23 AM
I just bought a new (to me) 5-lug space saver spare and it arrived yesterday. I couldn't believe that the thing weighed that much.
I weighed it as 32 lbs. I weighed one from a 74 911 and it was the same. I weighed my 930 spare and it was the same as well.
How/why did they make it weigh so much? A full size wheel/tire doesn't weigh much less if at all.
914-8
Jun 27 2006, 11:26 AM
QUOTE(JOHNMAN @ Jun 27 2006, 10:23 AM)
The 911 spare pretty much is a full size spare (it's not a mini spare donut like you see on domestic cars). It's just a folded up full size spare.
Aaron Cox
Jun 27 2006, 12:09 PM
put it on a fuch.. much lighter then
see my blog
dflesburg
Jun 27 2006, 12:12 PM
Geez John,
Get a AAA card with unlimited towing... it fits in your wallet. Plus tow truck drivers are fun to ride with...
Like Goober on Dukes of Hazzard. Good ole boys.
John
Jun 27 2006, 12:58 PM
QUOTE(dflesburg @ Jun 27 2006, 10:12 AM)
Geez John,
Go run a marathon or something....
JmuRiz
Jun 27 2006, 02:08 PM
QUOTE(Aaron Cox @ Jun 27 2006, 10:09 AM)
see my blog
Now that's cool...I noticed the same thing when given a space-saver...heavier than my fuchs spare. Did you use a new space-saver tire and mount it to a spare rim you had?
Aaron Cox
Jun 27 2006, 03:00 PM
QUOTE(JmuRiz @ Jun 27 2006, 01:08 PM)
see my blog
used tire, took off rim and mounted on my fuch...
usually the steel wheel is destroyed when taking off the tire.. the lip bends like a can opener to a can
Eric_Shea
Jun 27 2006, 04:46 PM
Should read:
usually the steel wheel is destroyed when SLITS is taking off the tire.. the lip bends like a can opener to a can
The man is a monster!
(damnit John, get some pics of the e-brake... and some 2%)
horizontally-opposed
Jun 27 2006, 05:17 PM
Using a Mahle gasburner for a spare (8.8 pounds if I remember it right, but someone will correct me, I am sure).
That said, I have no idea what the 205/55R15 BFG on it weighs. That thing is old and doesn't let the trunk floor lie flat. Maybe it's time to get a skinny tire for the spare? Ah, but then does a different diameter matter in back with no LSD?
Or do I just swap a front for a rear and then a spare up front if it gets to that?
Finally, what is the lightest 15-inch tire that could be used as a spare? Could a collap-suh-ble be put on a Mahle like it has been on a Fuchs a la 916 (from BFG, no less)?
pete
Eric_Shea
Jun 27 2006, 06:03 PM
You can put the collapsable on any 15x6" rim I would imagine...
T H O M A S
Jun 27 2006, 06:10 PM
5.5x16 spare from a 993 turbo,aluminium
