John
Jun 28 2006, 12:56 AM
Eric, since you asked so nicely in the thread that we hijacked, here are some pics of my e-brakes using stock 914 brake cables. I just finished them up, and there are some slightly fuzzy pics, but here they are..... (pre-blog even)
John
Jun 28 2006, 12:57 AM
more
John
Jun 28 2006, 12:58 AM
more
John
Jun 28 2006, 01:00 AM
more
John
more
John
Jun 28 2006, 01:12 AM
5 clicks and they are SOLID.
I wanted to utilize standard cables so they can be replaced if required and so others may benefit from this approach.
I created a pivot by drilling a hole in the trailing arm and welding a nut over the top of the hole (so that the threads could extend into the trailing arm. I am using a shoulder bolt with a bronze bushing as the pivot. The belcrank I designed is as thick as would easily fit inside the stock 914 cable ends (3/16"?) .
I played with the geometry until I felt comfortable that the stock brake handle would provide enough travel to actuate the e-brakes, and came up with the location of the pivot point.
I made one modifications in the middle that didn't show up well in the pics.
The 40mm anchor block that I originally welded to the backing plate was cut off of the backing plate and welded to the trailing arm for strength.
Through trial and error, I decided not to utilize the small helper spring for the bow-ties.
I am also only using single bow-ties to expand the shoes. I read somewhere that some later 911's were done that way (but I didn't verify that).
So far, they work well beyond my expectations. They feel as solid as the ones in my 911 Turbo.
(I know I need to touch up a few scratches I made in my paint. Luckily I didn't scratch through the POR-15 anywhere.
RON S.
Jun 28 2006, 04:52 AM
John,
That is absolutely beautiful
Clean,and fully functional.
Now,bring a set with you to Hershey next year,and I'll bring'em home to install on mine.
Ron
turboman808
Jun 28 2006, 05:58 AM
That looks really nice. Dam I want a emergency brake already
Jeroen
Jun 28 2006, 06:13 AM
I really, really like the belcrank idea
No need for custom cables / crappy routing
Excellent thinking (and execution) !!!
Eric_Shea
Jun 28 2006, 10:40 AM
Me likes too...
This had me thinking all last night about a threaded rod like what's on the back end of the 911 cable.
Hmmmmmmmmmm
Aaron Cox
Jun 28 2006, 10:43 AM
how much?
John
Jun 28 2006, 11:14 AM
QUOTE(Aaron Cox @ Jun 28 2006, 08:43 AM)
how much?
For what?
I rebuilt old trailing arms I had.
I bought the e-brakes from OTTO.
There is quite a bit of trial and error that went into this project before the end result was achieved.
If I were to put together some sort of hardware only kit with templates of where to weld nuts to the trailing arms, I would probably be around $50 + shipping for the pair.
Unfortunately, at this time I have my hands full of another little project that has been delayed beyond all my wildest dreams (tripple gauge kits), and I can not take on any more projects until that one is off of my plate. (I hate relying on others to help me with projects {can you say screen printers suck ass?})
I know a couple people I need to call now and chew on their asses......
Aaron Cox
Jun 28 2006, 11:19 AM
how much and what year ebrake assemblies?
they work with stock 914/6 rotors? or do they need to be vented?
looks killer.
definitely make up hardware kits
John
Jun 28 2006, 12:43 PM
The e-brake assemblies can be any year 1971-1989, but the early ones (steel trailing arm ones {1971-1973}) will fit without modifying the rear wheel bearing retainer bolt holes. In 1974, the 911 went with larger rear wheel bearings and aluminum trailing arms.
The later e-brake assemblies need to be modified to work with the smaller bolt pattern (holes need to be slotted) and the 914 bearing retainers need to be modified to work with the e-brake backing plates. (It's simpler to use early parts)
Mine happened to be the later parts. I believe the price range for the e-brake assemblies may vary but I found around the $150+/- range to be about right.
The rotors and calipers are pure 911SC parts (which are cheaper and more available than 914/6 parts).
I wanted to use parts that are common and available and as inexpensive as possible.
I can buy rotors and pads at the local FLAPS.
I even went so far as to switch to 911 CV joints mounted to modified 914/6 axle shafts. My inner and outer rear hubs are all 911 parts, as are my transmission output flanges........
echocanyons
Jun 28 2006, 01:25 PM
Excellent idea, and execution!
This owuld solve my no e-brake problem and seems much more doable than to have the cables modified.
I would certainly be interested in the modification parts if anyone is willing to produce them?
John
Jun 28 2006, 01:39 PM
I could do the hardware kits less e-brake parts, but it won't be very soon. I would estimate fall (Aug/Sep time frame).
I must complete my current project before taking on another one.
Eric_Shea
Jun 28 2006, 01:42 PM
I'd be willing to bet you need a 911 rotor.
Maybe Rich can do some measure'n for us? I'm still waiting on that front rotor combo measurement
John
Jun 28 2006, 01:53 PM
Like I said,
Yes they are 911 vented rear calipers. They are available through the usual suspects and were less expensive than 914/6 stuff the last time I checked.
davep
Jun 28 2006, 02:18 PM
QUOTE(Aaron Cox @ Jun 28 2006, 09:19 AM)
I've never seen 914/6 rear rotors with an internal drum.
Perhaps the 912E rear rotors?
Jeroen
Jun 28 2006, 04:19 PM
do the SC rear calipers bolt straight up onto the 914 trailing arm?
any mods/spacers?
John
Jun 28 2006, 05:42 PM
The SC rear calipers (having the same bolt spacing as the rear of a 914) will bolt up.
They do need small spacers to center them on the rotor. The required thickness is:
(2) 1/2" SAE FLAT WASHERS
I like the SAE flats as they are flat on both sides and are smaller in OD than standard washers.
The spacers can be between the caliper and the mount (together with longer mount bolts) or under the rotor hat. I prefer between the caliper and the mount.
The only other modification I made to the calipers was to open up the mounting holes to 9/16". This allowed me to move the caliper radially away from the center of the rotor just a little. I did not turn the rotors down at all. The rotors are stock.
While the calipers cleared the rotors, I felt that I wanted just a little more room in there for thermal expansion (in case the rotors grow radially when hot). I now have almost the same clearance as a 911 has between the rear rotors and calipers.
Gary
Jun 28 2006, 06:11 PM
I would so be interested in a kit. My 911 ebrake cables are at best a kludge.
John
Jun 29 2006, 01:14 AM
Keep me in mind in a couple of months if anyone may be interested in the belcrank kit.
Say late August to mid September.......
If there is interest then, I will make some up, but I have my plate full until then.
andys
Jun 29 2006, 09:53 AM
QUOTE(JOHNMAN @ Jun 28 2006, 12:12 AM)
I opted not to do the conversion because of my fear of using just the single bow-tie. Not sure if it is strong enough by itself.
Also, that helper spring aids in pulling the cable back, otherwise the shoes could drag. As on my Wilwood spot caliper setup, I found I needed a helper spring for this purpose to ensure the cable pulled back to it's at rest position.
Andys
John
Jul 1 2006, 03:40 AM
andys,
Since the return springs are what retract the brake shoes (as is the case in all drum brakes), I made the decision to eliminate the "helper spring" between the two "bow ties".
Considering the amount of tension that the "helper spring" provides (very little) the decision to eliminate it seems legitimate. As long as the stock cables are in good shape, the tension provided by the return springs (which are quite strong) should be sufficient to retract the shoes and prevent them from dragging.
I made the decision to eliminate one of the bow ties because the design does not require two. Since my cable has a fixed end (unlike the 911 design which uses the second bow tie to anchor the cable end via the spacer tube) only one bow tie is required to spread the shoes. After reviewing the design of the bow ties, I determined that the strength of one bow tie is more than sufficient to spread the shoes and keep them spread as the angle of the opposing arms approach 180 degrees, the forces on the pivot points of the bow tie becomes less.
Only time will tell, but my decisions to modify the 911 design were carefully reviewed. It is not my intention to use the e brake as an e brake as much as I am a parking brake. "Helper springs" can always be added if necessary without much change, but if the cables are kept in good condition, this should not be an issue.
As a parking brake, the modifications that I made are more than sufficient as all the items will only see static forces. In the case where the car is attempted to be moved while the brake is set, the anchor block provides the resistance, as does the bow tie.
I will not go into some of the critical design issues that I see with the addition of the willwood spot calipers.
jim912928
Jul 1 2006, 06:47 AM
I'd be interested in a kit...have carrera brakes to put on, all the hardware for the rear ebrake stuff off an 84 carrera...and the backing plate from a 71...I just need your setup!
PRS914-6
Jul 16 2006, 12:29 AM
John, I am in the process of doing a similar installation except I have 69 911 parts and they go on without any slotting. On the 69, the shoe's are held from rotating by a welded block on the arm that goes up between the shoes. This prevents the shoes from rotating force when they are energized when moving. I did not see a a retainer on your set up and your pictures look identical to mine except the wider bolt circle. I ended up welding a similar piece of metal on the 914 rear arm that will prevent the rotation. How are your shoes restrained?, your pictures do not show a block. The hole on the welded piece on my arm is where the cable goes through
Where the block goes:
The block off the 911:
What I welded on my arm:
John
Jul 16 2006, 02:46 AM
Yes you need the anchor as I call it to be welded to the trailing arm. This is what resists the twisting forces caused by trying to roll the car with the e-brakes applied.
You have an excellent pic there. I didn't snap a pic of mine when I did it.
PRS914-6
Jul 17 2006, 11:43 PM
I finished one side of this conversion. John really had a good idea on this system. The tough part is the goofy angles and the difference in height between the cable and the pull rod. The pull rod coming out of the shoe is difficult to keep straight as there is just not enough room. Because of this, I did not use a clevis, I instead used a 6mm stainless bolt and a piece of angle iron for the bellcrank to drop down in the low spot. It's very close to being straight. In addition, instead of welding a nut on the arm, I welded a 10mm bolt, using it as a stud but it amounts to the same. There was just the right amount of room to get the spring installed between the anchor block and the actuater arm to assist in retraction. Here is a picture, I hope it makes sense. John, good idea on this! I had been scratching my head trying to decide a method without making custom cables which I think would be nearly impossible to keep straight considering the angles.
John
Jul 18 2006, 12:15 AM
One thing that may need to be addressed before you get too far down the path, is cable length. The passenger side is less of a concern as the cable is longer and it's unsupported distance is greater (allows more flexability).
The issue may come up where when you lower the car, the drivers side cable becomes tight and will actuate that side e-brake.
When I was determining exactly what the location of the cable anchor was on the drivers side, I discovered this potential issue. As the control arm is raised up into the vehicle (as it does when you sit the car down on the suspension), the distance between the cable tube on the body and the cable anchor on the trailing arm increases.
My solution was to leave enough slack in the cable that this would not be an issue under full compression of the control arm. When in the raised position, the e brake cable can touch the header on the drivers side, but when down on the ground, there is not enough slack for that to happen.
PRS914-6
Jul 19 2006, 12:25 AM
John, couldn't you screw the outside cable adjuster out which will make the outer cable longer or install a short spacer between the outer cable retention blocks and the cable? Then fabricate a little extension piece for the inner cable if needed? Sounds like you only need a little bit, maybe 3/4"??
John
Jul 19 2006, 12:54 AM
My setup is fine.
I was just warning others of a potential pitfall if not thinking out the whole problem from the beginning.
After I figured out that the effective cable length changed during suspension travel, I redesigned my belcranks to locate the cable anchors closer to the pivot of the trailing arm by approximately 1"
Yes, if you ran into a difficulty, a "cable extender" could be made, but I wanted to keep mine very simple and straight forward using stock 914 cables and as few parts as possible.
Gary
Aug 15 2006, 10:04 PM
Hey John,
Still officially interested in a kit
John
Aug 15 2006, 10:19 PM
I'm still in a busy time of my life right now and will be for the next 3 weeks or so:
Closing on a house
Picking up a 914 Tub
Rearranging the garage for the other tub
getting these blank tripple gauge kits finished once and for all. (I shipped out the first two kits so far)
The list goes on.
The e-brakes are working flawlessly and I will be looking into a few "kits" of my belcranks and associated hardware in the weeks to come.
dion9146
Aug 16 2006, 06:16 AM
Count me in too John. Not in a big hurry, but I wanted to indicate my interest as well. Having parked my 914 on a slopped driveway last night, it made me nervous leaving it in gear (and of course not a brick or block of wood in sight). Thankfully, my nice new 'really good compression' engine held its ground for a couple of hours.
Thanks,
Dion
Jeroen
Aug 16 2006, 08:05 AM
keep us posted please!
Aaron Cox
Sep 3 2006, 09:17 PM
looks like a killer setup....
free interest bump
jim912928
Sep 4 2006, 07:41 AM
I'm still in for a pair when you have them!
bd1308
Sep 12 2006, 07:56 AM
Let me ask a stupid Q
Are these able to be put onto standard /4 hubs?
John
Sep 12 2006, 08:13 AM
QUOTE(bd1308 @ Sep 12 2006, 05:56 AM)
Britt, these are for use with vented 911 rear rotors with integral drum e-brakes.
4-lug rear discs do not have the drum inside.
You could potentially use redrilled 914/4 hubs with the 911 rear discs if that is what you are asking....
The whole reason for something like this is when you switch away from the stock 914 rear calipers that have e-brakes built-in.
I went with stock 911SC rear brake calipers/rotors/e-brakes.
heavydriver
Sep 12 2006, 09:40 AM
Could'nt you just redrill the rotors to the 4 bolt spacing and end up with better brakes/e-brake/and the sleeper look ?????
John
Sep 12 2006, 09:56 AM
QUOTE(heavydriver @ Sep 12 2006, 07:40 AM)
Yes. When it comes right down to it, if you can think it, it can be done......
Gary
Oct 5 2006, 09:12 PM
Still interested bump
PRS914-6
Nov 29 2006, 05:51 PM
QUOTE(JOHNMAN @ Jul 17 2006, 10:15 PM)
I ran into this same issue, cable gets pulled too tight on suspension movement. It really needs an extra inch or two so I will move and re-weld the cable anchor point backwards by 2" and install this home made cable extender. It only adds one pin and should be trouble free.....
jim912928
Nov 29 2006, 08:56 PM
John...I'm still interested in a kit!
Gary
Feb 11 2007, 01:19 AM
Hi John,
I'm resurrecting this thread
. Any chance of getting a kit / templates in the next few months? I'm deployed right now, but bought the Shine needle bearings and will install them this summer when I get back. Would be great to redo the e-brake stuff when the trailing arms are off.
Thanks, G.
Heeltoe914
Feb 11 2007, 06:17 PM
QUOTE(Gary @ Feb 10 2007, 11:19 PM)
Hi John,
Thanks, G.
I am still interested.
John
Feb 12 2007, 12:58 AM
I have thought quite a bit about how to offer a "kit" for this.
I don't know if there would be enough interest at a cost of $100.00+.
If there really is interest in kits priced in this range, I can try to put together some parts and templates for positioning the pivot points.
These can not be a simple bolt-on kit and will require cutting and welding on the trailing arms.
Regardless of interest, I will create a second set for a second car that I have.
Either PM or E-mail me if you are really interested.
Luke M
Feb 12 2007, 08:35 AM
John,
I could use an e-brake kit. Keep us up to date if youre going to offer a kit
for sale.
Luke
PRS914-6
Feb 12 2007, 09:35 AM
John, you may have to offer an exchange rear arm program to do it. I suspect most people will want a bolt on setup but I could be wrong.....
