shaggy
Jun 28 2006, 03:48 PM
i need to make the plates that will be welded to the front fenders under that gas tank for the 13mm front sway bar i have.
im planning on cutting them out of steel.
what thickness should i use?
i know i saw a template for them awhile ago but cant seem to find it now...
anyone know where it is?
-shaggy
SLITS
Jun 28 2006, 04:04 PM
match the triangle on the outside that holds the rubber or save yourself some trouble and buy them ready made with weld nuts from Engman (I think), 'cause your gonna need nutz to bolt the outer piece to.
Jeroen
Jun 28 2006, 04:15 PM
yep, get the Engman plates
check the "parts & resources" forum for info
Kargeek
Jun 28 2006, 09:21 PM
I made mine out of 3/16"- 1/4" plate shaped to match the trangular shaped impression on the wheel housing. I tapped the mounting holes- and even welded nuts onto the plates. Welded them on the inside gas tank area wheel housing. Now, I can remove the bushing retainer from the outside.
DH
East coaster
Jun 29 2006, 08:00 AM
Ditto........I made mine from 1/4" plate, drilled/tapped them and welded them into place.
Click to view attachmentClick to view attachment
shaggy
Jun 29 2006, 09:24 AM
those look nice!
but i bought mine from engman last night.
thanks
-jim
andys
Jun 29 2006, 09:42 AM
Anyone here kind enough to post the hole pattern for both the three mounting bolts as well as the diameter of the center hole for the sway bar plate? I would greatly appreciate it.
Thanls,
Andys
Eric_Shea
Jun 29 2006, 09:43 AM
I was gonna say... make them outta some dead Presidents. Mark Bland (Engman). Good call.
elwood-914
Jun 29 2006, 09:49 AM
QUOTE(andys @ Jun 29 2006, 08:42 AM)
Thanls,
Andys
There are some patterns on the bird site.
East coaster
Jun 29 2006, 04:32 PM
Can't go wrong with Engman's goodies. I've bought a few of his products and they are well made and a great value.
