rezron
Jun 28 2006, 09:25 PM
I'm thinking I saw a thread in the past but I can't find it now. While doing some cleanup on an inner CV joint the bearing cage and bearings came apart. What's the correct technique to reassemble? I can get it together but can't get it to pivot
correctly?
Thanks in advance,
Ron
Allan
Jun 28 2006, 09:28 PM
The Haynes manual has a pretty good description on how to get them back together.
When I did mine it took me a couple of tries but it eventually went back together okay...
rezron
Jun 28 2006, 09:47 PM
Thanks for the advice- I'll take a look at the Haynes manual.
Ron
rezron
Jun 29 2006, 10:07 PM
Thanks for the help! It went together perfectly on the first try!
Have a good 4th!
Ron
nbscooters
Jun 30 2006, 02:18 AM
If it worked first try, you might have not got it in correctly. A while back I remember I thought I had it first try but if the CV doesnt move up and down the shaft, then you dont have it fitted correctly.
ps. dont forget your MoS2 paste
