mike373
Jun 29 2006, 11:06 AM
Out of nowhere I have a strange sound coming from the passenger side rear area. The sound is a toc toc toc toc toc on acceleration.....and a tic tic tic tic on decceleration. Does this sound like a failing CV joint, and do they go suddenly like that??
Thanks,
Mike
Joe Bob
Jun 29 2006, 11:08 AM
Clicks and thumps when turning......when getting towards end of life it will make noises in a straight line. Best to repair prior to failure....
Air_Cooled_Nut
Jun 29 2006, 11:09 AM
Sounds like it to me, that's the sound they make. It's the big ol' BB's in there rattling/dropping in the cage.
Air_Cooled_Nut
Jun 29 2006, 11:11 AM
Here's a good test:
Grab axle. Push/pull it up and down. If it moves then CV is bad. It's okay for the axle to move in/out (back-n-forth between tire and tranny).
nomore9one4
Jun 29 2006, 11:41 AM
I believe I have this same problem. When I start off I hear a clunk like when a universal joint would go bad.
Now I just need to find one and get the time to replace it.
Mark Henry
Jun 29 2006, 03:21 PM
QUOTE(Air_Cooled_Nut @ Jun 29 2006, 01:11 PM)
But it's not OK if the trans output shaft moves in and out...the thing the CV is bolted toon the trans.
mike373
Jun 29 2006, 03:37 PM
The sound is pretty damn loud too. Almost sounds like the brake caliper is rubbing on the wheel....... but it's not...I already checked that. Gotta pull the wheel when I get some time.
Mike
Eric_Shea
Jun 29 2006, 03:44 PM
Clunk, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click, clunk, grrrrrr, grrrrrrrrr, click, click...
GWN7
Jun 29 2006, 03:50 PM
Check your CV bolts. The toc toc, tic tic noise could be the the plates flapping around. (insert Dr. Evil CV bolts plug if I'm right)
