QUOTE(Midtowner @ Jun 29 2006, 09:13 PM)
Is this normal?
not normal, but not uncommon either ...
a few things, first, check and double check the 4 bolts that bolt the column plate to the body. then doublecheck them again ...
the bearings that hold the assembly to the shaft can wear in two way,
- the inner race won't fit schnugg to the shaft anymore. the fix for this is a metal "sleeve" that fits around the shaft and is tapered (sp?) to slide between the shaft and inner race.
- the outer race has worn the actual casting in the housing and is a lose fit. i simply put some tape around the outer race until it fit schnugg inside the housing.
hope this helps,
Andy
