So I have 22mm Tbars, 21mm Front sway bar, Turbo tierods, polybronze bushing, konis, ball joints, konis in the rear with 200lb springs on adjustable perches, 911 front vented disc with Carrera calipers, close ratio gear box, 120hp 2056cc motor with Djet.
Its fast, handles amazing and on a bumpy street its STIFF. Loafing down the freeway at 70 its fine, on a track its predictable and keeps me outta trouble. AXing its fast and neutral handling so I can toss it around or let the rear hang out on tight hair pin turns under control.
Depending on the parts you bought you will have the biggest grin on your face when you drive it.
