ptravnic
Jun 30 2006, 10:31 AM
OK, either stock or slightly modified Bosch FI - what's the upside of 1 versus the other?
Bleyseng
Jun 30 2006, 10:35 AM
-2 more degrees of exhaust duration to let more exhaust flow out (ie heat)
ptravnic
Jun 30 2006, 10:44 AM
Which has the lower degree, 73 or 9550? btw, you are a champ w/all the questions you answer
Cap'n Krusty
Jun 30 2006, 10:45 AM
Jake says his cam works. Web Cam says theirs works, too. His may, theirs makes LOTS of HCs, especially at idle, and won't pass smog and run well at the same time. In fact, we could never get it to pass smog, period. HCs are unburned fuel, meaning there's something wrong with the cumbustion process. Overlap and early EFI don't get along. The Cap'n
ptravnic
Jun 30 2006, 10:51 AM
I guess I'm lucky to live in a no smog state (NY) but that explains a bit about why I can't get my engine (w/webcam 73 ) to idle properly. Although I was able to pass smog inspection when I lived in NJ... Then again, the idle prob could also be the misadjusted MPS which is in the process of being cured (THX GEOFF aka BLEYSENG!). I'll most likely break down and buy an LM1 to get things all proper like.
Nuff about me
