QUOTE(GeorgeRud @ Jun 30 2006, 05:58 PM)
We replaced ours several years ago and the price was about the same. We went with the 95% furnace, and it's helped with raising gas prices. The units themselves are all pretty much interchangable these days, the AC and ducting is the hard part.
If you're handy enough (it looks like you are), you might be able to do it yourself unless there's some strange building dept. restriction. You might try Lowe's or Home Depot as well.
The only thing I found is that with the high efficiency units, you might have to sleeve down your chimney, or like ours have it exit through PVC piping on the side of the house. Also, since there are many more relays and control boards for the different motors, the highest efficiency units may have more breakdowns.
Now you know why I stiff have carbs! Good Luck! George
George,
Thanks for the info. If was nice to meet you when you came up. Did the "boss" say no to another car??
That is one good thing about the 95% furnace he quoted me on. It had a 10 year parts and labor warranty.
