I've just started running my new motor which is a 2.2 and change with a compression ratio of about 9.5:1.
I have a good VDO temp gauge and it's sensor installed in the sump of the engine. I've been finding temperatures of up to 220F on the motor under street driving conditions. I've also noted a loss of HP at these temperatures I believe. I've heard no engine pinging at these higher temperatures though.
My plugs show that I am not to lean or too rich but just right.
Does anyone have some feedback for me on when I should suppliment the factory cooler? Or should the factor fan and cooler be sufficient to do the job?
PS - If you think an extra cooler is in order, is there anything out there that would be ideal for a rear mounted cooler? IE not chopping the front trunk.
THanks!
I also just took some shots of the new ride today too...
Pics before I raised the front end.
-JR-
