Full Version: Lock tumblers
dryheat914
Hi all,
I'm looking for someone who can take all the tumblers from my car ( none are the same ) and match them up with one new key. I am using two cars to make one and the P.O.'s of these car have have new ignitions etc. added. I would like one key to fit all my locks.
Thanks
Slowpoke
You can do that yourself. Take all the locks apart. and clean everythng. Then use the good ignition key and one lock and just start fitting the tumblers so they will work and move to the next lock. When you take them apart you will see how it works. Your will run out of the ones you need that fit. Then put the ones that don't fit together and file or sand them down. All the locks use the same tumblers. If you leave just one or two pins in the glovebox lock I'm sure that will do just fine. That is all a locksmith will do and ask for a $100. Then, just clean and lube everything with graphite and your are done. It takes about two hours. I just did the same thing but I didn't have the ignition key to start with, so I took just that to the locksmith. smile.gif
I guess the biggest problem is these locks are junk and when they are 30 years old .....well, that makes them more like crap. With two cars you should be able to make one decent set.
campbellcj
I have done this several times and agree that it is pretty darn easy. R&R'ing the lock cylinders from the car is the hard part!
One nice option that I think has recently dried up on us 914 guys (i.e. gone NLA) is to buy a new ignition switch key portion, which comes with a pair of brand new factory keys and a key-number tag. You replace the electrical switch at the same time. Then you rekey everything else to match. Voila, a new reliable ignition switch and brand new sharp key that works the whole car. What a concept.
ss6
As luck would have it, I just went through replacing the electrical portion of my ignition switch (start circuit not engaging).
Still having trouble, seems to be something with the tumbler portion not fully engaging the electrical switch (there seems to be a "push" action as well as a "turn" action).
Since the mechanical part of the switch is NLA, anyone have any ideas (or sources)?
Demick
Like Slowpoke says, it's really easy. If I recall correctly (I did it 5 or 6 years ago), there are only 4 different tumblers, and I think the number of each is even stamped on the tumbler itself. So once you figure out the first key, write down the key code (tumbler number for each position), and make them all match. Once you are familiar with it, you'll be able to just look at a key and identify it's key code.
Demick
Red-Beard
There is indeed an article on the Pelican site and I think both Pelican and AA sell the re-keying kit, which has lots of extra pins for the tumblers.
James
silver six
Dryheat,
I don't think there is anything wrong with letting a locksmith do this work but it has been my experience, at least here in the Bay Area, that for whatever weird reason rekeying the locks with correct wafers (wafers are the little flat bits; American cars have pins, we have wafers) and a fresh key cut from the key number is either absurdly expensive or practically impossible. Apparently the wafers are no longer made. I mean no one can get them, not the VW or Porsche dealerships (I tried a few), not the locksmiths (I tried at least four), and not the parts suppliers (I tried a number of sources including Pelican).
I ended up rekeying most of the locks myself using scavenged wafers. If I were to do it over, this is what I would do:
1. Fresh Key: First get a fresh laser cut key from a key number. How do you figure out your key number? Take the ignition tumbers (the tumblers is the cylindrical unit in which the wafers and little springs reside) to a locksmith that has a laser key cutting machine. Ask your local Porsche dealership for a referral. If they do not have a laser key cutting machine go somewhere else! Tell the locksmith that you want (1) a key freshly cut on the laser corresponding to the ignition tumblers and (2) you want to know the key number (sometimes referred to as the "key code"). Now with this number you can forever cut fresh keys without any concern of copy degredation. Copy degredation occurs when you copy a new key from an old worn out key. The effect is like taking a photocopy of a photocopy. Each copy you make contains more and more errors and more and more junk.
2. Remove All Your Locks: Now with your fresh key in hand you can rekey the great majority of the rest of your locks. Pull out all the locks at once and do them all at the same time. You will need to do this in order to redistribute all the wafers located in your tumbers. Pull the following locks (1) trunk lock, (2) two door locks, (3) glove compartment lock, and (4) front trunk pull lock. Removing these various locks is tremendously easy. If you have any trouble just refer to the shop manual or ask me/us here on the BBS.
3. Remove the Tumblers From the Locks: Removing the tumbers from the locks is also very easy. Some of the tumbers are kept in place by philips screws holding the cams on. The front trunk release tumber is kept in place with a tiny flat head screw located on the side of the lock. The glovebock tumber is kept in place with a similar system except instead of a tiny flathead screw on the side, it has a tiny pin that has been jammed into place. You will have to carefully drill out that pin. You will know where to drill because there is a pretty obvious indent there.
4. Remove Wafers From Tumblers: Now carefully remove the little wafers from the tumblers. Leave the little springs in. You don't have to remove them. You will notice each wafer has a little rectangular hole in the middle. Some rectangular holes are cut a little higher in the wafer, some a little lower. There are four positions in which the rectangular hole might be cut. Some of the newer wafers even have little numbers corresponding to the position of the rectangular hole (1-4).
5. Rekey Your Wafers: The idea is to insert the right wafer in the correct slot in the tumber to correspond to your freshly cut key. You know you have the correct wafer when the wafer in the tumber, with the key in the tumber puts the wafer perfectly flush with the surface of the tumber. In other words the wafer should neither be too high nor too low. On both side of the tumber, the wafer should be flush. Through trial and error and your supply of wafers provided by all your various locks you should be able to rekey probably three or four of the five locks. Start with your door locks and trunk lock first as they are the most important.
6. Running Out of Wafers: Now you want to rekey your glove compartment lock and front hood lock but you're running out of wafers. Here are your options from best (most difficult) to worst (most lazy). (1) Go to the wrecking yard and get wafers out of the tumblers of 914s and VWs of the same era. (2) Use the wrong wafers from the ones you have left over and just grind them down with a Dremmel until they're flush with the tumbler surface. (3) Get as many wafers in the tumber right as you can and leave the rest of the slots blank. (4) Leave the entire tumbler blank and don't worry about it; after all, it is not that big of a deal is it that your glove compartment and front trunk don't lock.
7. Reinstall: Reinstallation is reverse of removal. By the way, take it easy on the torque. The door handle nuts really don't need much torque. Too much torque on those nuts will pull the stud out of the door handle's weak pot metal.
A note about lubricants: Use a verylight coat of lithium grease on the wafers when installing. Take it easy on the grease. Use no grease on the springs. Keep the springs clear of grease if possible. Keep graphite powder out of there.
Douglas
dryheat914
Wow!,
Thanks guys!, I have dabbled a little with the door tumblers but haven't really got into it. I'm not in a hurry, as my car is being restored and not a daily driver ...yet. I will certainly hold on to the info you guys have shared.
This website is got to be the best thing since the 914 itself!!!! smilie_pokal.gif
