Hybrid_Teener
Jul 5 2006, 03:43 AM
"the 911 ST was made in tiny numbers. The cars were available with engines of either 2466 cc or 2492 cc, producing 270 bhp at 8000 rpm." ~Wikipedia
whaaaa???
that sounds awesome. I want one, cept that would probably be too expensive.
Anyone build up their 2.4 to ST specs?
Anyone _HAVE_ the 2.5ST specs at all???
I know they used lots of lightweight parts and stuff on the engine (to reduce parasidic drag etc i think..) but which parts? 280hp sounds sweet.
k thanks
~Aaron
Jeroen
Jul 5 2006, 07:55 AM
check the taildragger section of the bird-board
lots of info there...
914rat
Jul 5 2006, 05:16 PM
QUOTE(Hybrid_Teener @ Jul 5 2006, 01:43 AM)
whaaaa???
k thanks
~Aaron
I think I remember reading about that in Dave Andersons book on 911 performance.It would be way to costly to buy or build.I think I'll have a V8 instead.
TravisNeff
Jul 5 2006, 05:20 PM
Eric Shea and Michal Richard are both building 2.5 short stroke engines for their teeners.
Trekkor
Jul 5 2006, 05:46 PM
I may...
KT
lapuwali
Jul 5 2006, 05:56 PM
A 2.5 short stroke wouldn't be all that expensive (relatively speaking). A 2.0 or 2.2 starter engine (66mm crank) with 90mm cylinders (stock diameter for the 2.7, so commonly available) plus 90mm pistons (NOT 2.7 CIS parts) and cams will get you there. You'd need full PEFI or carbs to get that kind of power, and it would require a lot of revs to get 250+hp. I doubt a short-stroke 2.5 would be a very good AX engine, as you'd be shifting a lot to keep it in the powerband. It would likely be a nice track engine, though.
TimT
Jul 5 2006, 06:46 PM
one of the problems with using the 2.7 p/c to make a 2.5 on a short stroke crank is that the compression ratio will end up being rather low. I think in the 8:1 or less range.
You could buy just the 2.7 jugs, and then have a set of JE or Omega or Arias etc pistons made to make a compression ratio of greater than 9.5: or so.
Now that would be a sweet engine.
Van914
Jul 6 2006, 03:39 AM
Here is one for sale on the Bird Board. I would like this for the track but street and auto-x I would prefer a little more torque.
van914
2.5 Short Stroke FS
ChicagoPete
Jul 6 2006, 11:47 AM
Real parts for a true 2.5 ST motor are very rare...and expensive
86.7mm Mahle p/c(10.3:1) and 70.4mm stroke...2492cc 270hp@8000rpm
87.5mm Mahle p/c(10.3:1) and 66mm stroke...2380cc 230hp@7800rpm
Very, Very rare and expensive p/c to find..not to mention the heads...
Build a 2.6L short stroke...92mm p/c with 66mm, that motor is a screamer. Heads need quite a bit of work with the RSR pistons...unless you use something like JE pistons...far cheaper alternative than Mahle stuff
redshift
Jul 6 2006, 11:53 AM
When mentioning Eric Shea, never forget to placcard it with "the crazy guy".
M
TravisNeff
Jul 6 2006, 12:06 PM
It was implied
Brett W
Jul 6 2006, 04:43 PM
How similar is the 993 engine to the early stuff. Could you take the crank from an early motor and combine it with the better cylinders and heads from a 993 engine? That would be a great motor. Lots of revs and much better heads than the early stuff.
Al Meredith
Jul 6 2006, 08:20 PM
About two yease ago I bought a 2.4L T engine that was running 10 years ago "when we put it up"said the PO. My son installed it in a 914 and it started right up (we used carbs). Pulled 160HP at the wheels ....not a "t" which is 140HP at the crank.We decided to rebuild it anywhy. It had 87.5 MM bore and stock 2.4 crank. The rods were polished and the case was "rounded". The flywheel was very light.
Two of the cylinders were broken at the very top allowing blow by under the casket. Just finished assembling (fired up nicely) Had to go to LN engineering for a custom set of nickies because we wanted to stay with the unique 87.5MM pistons. Everything was redone or replaced, including case work by CE. Been to the dyno to pull a couple of hard pulls for breakin. I think it got to 170 HP at 5000 RPM with just points and a blue coil..no spark box. Once dialed in we are lookin for 200 HP at the wheels ; maybe 223 +/- at the crank. We will keep the board advised as we progress. Al
