Okay, I got my car running again, sort of....
But, I have a problem I can not figure out.
One cylinder is cold.
#2 cylinder is dead. I pulled the plug, and is is wet with gas.
I switched the wire.
I switched the plug.
The plug fires out of the cylinder.
The injectors were tested.
There is compression.
In the same vein, I am not getting good vacuum, so the airflow sensor is
not opening enough to keep the car running. Would a nonfiring cylinder
cause that? Will I pull more vacuum with them all running? I can not find
any more vacuum leaks. I've been through them all a few times.
Anybody have any ideas? I'm getting excited again!!
Thanks,
Jeff
