Just wanting to know if the forward coupler set screw is suppose to fit flush? Also any tips on the shifter reinstall? Meaning anything special I need to know? I have a Stock 73 914. Thanks Stieve
tdgray
Jul 6 2006, 06:10 AM
IIRC... Mine does not sit flush.
I assume you have the correct cone screw.
Nothing really special that you need to know.
Couple things you might want to do while your in there though.
1) replace firewall bushing.
2) use new cone screws when installing. There has been some discussion here about thier limited use design.
Oh and BTW. If you get a hard shift lever after all is hooked up there is a procedure to adjust the shifter. I think I found it on Pelicans web site.
scottb
Jul 6 2006, 06:37 AM
my front cone screw does not sit flush. my rear one does however sit flush....
double-a
Jul 6 2006, 07:57 AM
+1. my front cone screw does not go in all the way, the rear does.
~a
Bleyseng
Jul 6 2006, 08:17 AM
Ya just need to hit it harder to make it fit!
KaptKaos
Jul 6 2006, 08:35 AM
QUOTE(double-a @ Jul 6 2006, 06:57 AM)
~a
+2
And when you put the coupler back on the rear rod, make sure you have the set screw facing down.
