northern tool has one for $279 that is polyethylene with built in lighting
That is virtually the same cabinet that I have had for the last 8-9 years. I like the fact that it won't rust, but I hate the fact that it is not as rigid as a sheet metal unit.
The large flat surfaces tend to bow. The large plastic window is OK, but it tends to leak due to the bowing of the top. I solved this issue on mine by attaching some angle iron to the inside of the unit to stiffen the flange.
It is about time for me to revamp mine (replace seals, replace gloves, replace gun, suction hose and tubes, rework my dust collection, etc.)
I would suggest that you buy some ceramic or better nozzles. The steel nozzles do not last long. The ceramic are better, and I hear that there are better nozzles out there (better than ceramic).
Good luck to you.
