I'm about to tackle the gauge cluster wiring, it seems that there are some wires that are not in the correct place etc.. I was wondering if there were any diagrams of the gauge cluster wiring or any pictures of a later model teener with the correct wiring for the gauge cluster. I have a combo gauge that I'm going to install and want to go thru the wiring an make sure that it is all correct.
StratPlayer
Oct 10 2003, 11:17 AM
I have an extra one of these gauges if anyone is in need.
Brad Roberts
Oct 10 2003, 12:08 PM
We need to scan the color'd wires diagram.
You might be better off asking what wire color does what.
Like list off everything you see on the BBS and let us tell you where each wire should go.
I can look at it and tell you.. but I cant tell you from memory.
B
Kerrys914
Oct 10 2003, 12:26 PM
If someone can fax me a hand sketch of their corectly wired gauge cluster I will pretty it up of posting on the club site.
Or Three close up photo's e-mailed to me kerrys914@comcast.net
Cheers Kerry H 804-217-8520
StratPlayer
Oct 10 2003, 01:09 PM
Trying to post a sketch I made when I removed the gauges, but keep getting timed out on the upload of the sketch.
StratPlayer
Oct 10 2003, 01:20 PM
xoxoxxo
StratPlayer
Oct 15 2003, 02:16 PM
Maybe one of you can fill the rest of these out
Gauge Cluster Wiring (Combo Gauge)
Brown Wire = Ground Black w/Blue Stripe = Instrument Illumination Red w/White Stripe = Swithched Power On Green w/Black Stripe = ?? Blue = ? Green = ??
Dave_Darling
Oct 15 2003, 04:50 PM
Green/black == oil temperature gauge signal Blue == alternator light Green == fuel gauge signal
Green/red == oil pressure light Black == low fuel light
There may be others I'm forgetting....
--DD
StratPlayer
Oct 15 2003, 05:10 PM
Thank You Dave, deeply appreciated,
