seanery
Oct 10 2003, 03:19 PM
Cant get R,2,4.
1,3,5 are decent, but not exactly right.
wtf?
Brad Roberts
Oct 10 2003, 03:20 PM
You have the shifter set too far forward. Loosen it and pull the shifter back. This will give you the throw you need for R24.
B
Brad Roberts
Oct 10 2003, 03:21 PM
Loosen the clamp at the access hole. You acces it with a 13mm and a wrench on one side.
B
seanery
Oct 10 2003, 04:01 PM
I don't think it's that. I can't move the rod (by hand) into the R,2,4 gears.
It feels like it may be in a bind somewhere.
Brad Roberts
Pull the spacers out I installed in the bottom of the mounting for the shifter.
B
seanery
Oct 10 2003, 04:03 PM
I don't think that'll make a difference.
I was at the back of the car when I couldn't do it by hand, not at the shifter.
seanery
Oct 10 2003, 04:08 PM
the box is an 1/8 to 1/4 inch higher now, since the carrier was scrapped.
could this make the difference?
seanery
Oct 10 2003, 04:10 PM
this is the carrier not used:
ChrisReale
Oct 10 2003, 04:22 PM
Do you have the linkage installed correctly? Is is rubbing on a header/exchanger?
rhodyguy
Oct 10 2003, 08:43 PM
sean, iirc this is for a tailshifter. if ALL else fails remove the inspection cover at the very back of the trans, on the bottom. see if the rolled pin #11 p86 haynes securing the two levers is ok. #'s12 and 14 same page. i had a guy tell me i needed a new trany long ago. nope a 79 cent part. get a pan when you remove the cover gear lube is going to come out.
kevin
