QUOTE(maf914 @ Jul 14 2006, 07:30 AM)
QUOTE(drive-ability @ Jul 14 2006, 05:22 AM)
I am looking at ways to vent the engine bay because the airs natural flow is up through the engine grill and with the top off the hot air is drawn into the cab. I want seal off the engine grill and vent the hot air out the sides. The fans on the engine grill work against natural flow while driving. I would like to also look at finding an air deflector to help channel the air through the engine grill vent in a rear direction not up and over the targa bar. If I can find something that would fit over the engine bay grill that would work as well.
Do you intend to keep an air-cooled engine? If so, sealing the top engine lid grill and exhausting air with fans through the fender wells will result in no airflow for the engine cooling fan. You will have three fans fighting for air with no inlet.
I guess I don't really understand the problem with the stock arrangement. The engine cooling fan draws air into the engine compartment through the engine lid grill. While the engine is running this airflow is always into the engine compartment and through the engine. This airflow picks up the heat that is radiated or conducted into the upper engine compartment before it is forced through the engine to cool the oil cooler, heads and cylinders. It then exits the bottom of the engine. The only time air naturally flows in the opposite direction, up through the grill, is when the engine is not running, and natural convection causes hot air to rise.
The engine conpartment is a low pressure area due to the engine fan sucking tons of air. If the stock tin and rubber sealing bits are installed the fan pulls air thru the grill off the low pressure area behind the rear window.
Cutting holes for fans, hmmm, I think the fans couldn't keep up with anything and would disturb the engine cooling. Also all the road dirt off the tires would end up clogging the fans.
If you want more cooling go to a GT style engine grill as it let more air in.
Try this for a test:
Drive around on the freeway until the engine gets hot, then pop the engine lid. Wow, oil temps drop 10F atleast. More air in plus the engine lid distrubs the airflow over the targa top so there is a bigger low pressure area at the engine bay so air can flow in.
Also if you have the raintray installed remove it during the summer.
