http://www.914world.com/bbs2/index.php?show...c=55688&hl=Theres the other thread...
Heres my take on it...
"Not getting 380hp with a 630 carb.
Probably a typo.. 280hp... Which seems about right for a high revving 283 with all the gizmo's.
If it were my car, I would..
strip the interior (blue is not a good color)
Get rid of the CF inserts
Replace with charcoal or black...
If the 4 lug is re drilled, leave it, if its adapters, go back to stock..
Clean up the front trunk, carpet=bad, Amp=bad
If the radiator exit is under the car, modify it to the wheel wells.
Put a painless wiring kit in it.
Put a freekin pedal board in it.
Solder on a top to the radiator fill.. extention... prevent air from getting in the system.
Optima battery with appropriate holder
Cut the reinforcement out of the rear engine lid.
Then change out all bushings, bearings, ect...
I could see it going for 5-7k... It looks like a good driver."
