QUOTE(solex @ Jul 16 2006, 12:19 PM)
Anyone have a source for these items? Also how do you remove the aluminum mount (that holds the window scapers and the outer felt) from the outer door skin?
Got mine from Pelican... Not sure how to remove the aluminum, you dont' need to in order to install.
On the felt, just take a small screwdriiver, and pry the end up and lift. When installing, push edge down and push so the edges lock in place as you work yourway down. On the scrapers, (squeegee) material, there is a small channel in the material, tthat locks in the aluminum track. When I installed mine, I used a little hair spray. It acts as a lubricant when sprayed, and when it dries, it acts as an adhesive. Spray the channel starting from the back of the car, slowly pulling foward, and pushing down, to make sure it locks in the channel. I make it sound harder to install then it is, believe me...
