QUOTE(Gint @ Jul 17 2006, 11:25 AM)
Check the resources section. Chris Foley (I think it's chris) is making an jack mounted engine bracket for a 4 motor.
i have one of the engine/trany plates from chris and it works great.
i had never removed my engine/trans before and did it alone using this tool on my floor jack. i like the idea of having the car up and lowering the engine. i was able to stop, move the FI parts, lower a little bit, rearrange some other stuff, lower a little bit, find a hang up, raise it again, fix the hang up....
you get the picture. lots of flexibility.
it is a little wierd with the whole thing out sitting on the jack. pretty stable with a bit of wobble. not really stable enough to wrench on, on the jack (i tried). i put the whole thing on the floor to swap out the trans. then with a little inginuity, put it all up on jack stands (yes, alone) and did some other stuff.
install was really easy. jack it up and get it in. lots of flexibility.
a very good $90 investment.
