QUOTE(nycchef @ Jul 17 2006, 10:43 AM)
i'm back. fixed the fuel problems. have proper pressure and good flow but 1.7 d-jet from hell wont start now. have 12 volts at the coil and i think all the grounds and connections are good. put a wire in the spark plug wire ( as an extension) to check for a spark. saw a small one once but then it was gone. is there a better method and where do i go from here?
Don't quote me on this, but I'm pretty sure when you're checking the spark, you remove the sparkplug, plug it back into the plug wire. You'll ground the edge of the threads to the block or other ground, then crank the car. That should show you spark from the actual plug electrode.
