QUOTE(Tobra @ Jul 19 2006, 09:01 PM)
when my car had the exact same symptoms, it turned out to be the relay on the fuse block. I happened to have one, but i bet a VW one would work, it did for my turn signals
OK, I've been going through this same thing... sorta. I had driving lights and high beams, no low beams. So, I took all the fuses out and cleaned, rebent the holders. I took all the wires off the fuseblock, one at a time and cleaned the connections, I took off the ground wires near the headlights and cleaned the mounting surface and connectors... tried the lights. NOTHING.. lol.
Tonight I messed with that square silver relay on the relay board under the dash. I turned the lights on.. high beams worked fine. I clicked the switch, felt the relay click over. No lowbeams. Now I wiggled the wires on the relay.. .HAY! my lowbeams just flashed. so I wiggled that one wire again... which on mine was the white wire. it works. I leaned the wire over and taped it to the side (just to keep pressure on it) and I have both headlights now. I'll try to find a new relay this week. I don't drive in the dark anyway.. but, that's where I found my problem. Now, if I could just get my headlights to CLOSE when I turn them off...
