Mike T
Jul 17 2006, 06:29 PM
I am somewhat familiar with antidive characteristics with a double a-arm type suspension but was surprised today when I read on the Pelican board a discussion of increasing antidive on a 911 front suspension(similar to our 914) by shimming the front torsion bar mount down.
Has anyone played with that at all? What was your result? How much of a shim would be needed?
Mike T
Joe Ricard
Jul 17 2006, 08:08 PM
Hmm, I just increase the rebound in my Koni's. and also installed 22mm torsion bars.
Keeps the ass end planted under hard braking so the back tires can help a little bit with stopping the car by slowing weight transfer.
I suppose somebody with good understanding of roll centers and stuff can add a BUNCH more.
drgchapman
Jul 17 2006, 09:07 PM
The Smart Racing PDF catalog mentions this mod on page 43 in the ERP 935 front suspension upgrade kit. www.smartracingproducts.com
They raise the inner pivot point 20mm. This would effectively lower the car a little. Lowering the front pivot will raise the front of the car slightly.
This will change the geometry as well, presumably for the better.
groot
Jul 18 2006, 06:46 AM
The benefits are certainly debatable. The downside is impact harshness and the inability for the suspension to keep the tire on the ground when facing a sharp bump (transition to concrete for example).
Mike T
Jul 18 2006, 07:36 AM
QUOTE(groot @ Jul 18 2006, 04:46 AM)
Maybe that's why Staniforth says it goes in and out of fashion in the racing world. There are tradeoffs.
I have a V8 autocross car and I am fighting rear end looseness on hard braking. When I stop with the steering dead straight there is no problem but add any steering input and the rear tends to want to slew around.
I have adjusted rear Koni firmness and it seems to help with a firmer setting but then in transitions such as a high speed slalom the back gets looser.
The front bites well with no understeer.
This week I am evaluating the car. Alignment settings, bushing condition, etc.
Car Specs;
weight 2215 with driver
58% weight on rear
52% weight on drivers side
Koni reds front and rear
250lb rear springs
22mm torsion bars
22mm Welt front swaybar set about 1/2
no rear swaybar
-1° camber front
3/16" toe out front
?° camber rear
0 toe rear
23.5x12-15 Hoosier R25a rear on 14" wide wheels
22.5x9-15 Hoosier R25a front on 10" wheels
Weltmeister Polygraphite bushings front and rear(8 years old)
camberball upper strut mounts
turbo tie rods
welt bumpsteer spacers
lowered with front control arms and rear semi trailing arms parallel to ground
Mike T
drew365
Jul 18 2006, 08:26 AM
If you're not suffering from understeer, you might be able to step up to 23m torsion bars up front to keep the rear end in place. Just a thought.
Jeroen
Jul 18 2006, 08:52 AM
braking and turning at the same time is never a good recipe in any car, specially in one with a rear weight bias
you can use it to your advantage (trailbraking) but other than that, try to avoid it
you could also add some toe in at the rear
if you have 0 toe at stance, then unloading the rear will cause toe out and that will cause more/easier oversteer
from what I gathered, shimming the front of the a-arms effectively causes your front susp. to bind up (move less freely) and thus you get "anti dive"
but I'm sure you'll sacrifice in other handling areas
might be worth to look if you can shift some more weight from the back to the front (move parts around in your car)
groot
Jul 18 2006, 10:22 AM
You have too much rear brake bias.
Joe Ricard
Jul 18 2006, 10:28 AM
Mike T, I love your car set up. very similar to mine except you have that mad Horsepower yo!!
Mike T
Jul 18 2006, 10:53 AM
[quote name='Jeroen' date='Jul 18 2006, 06:52 AM' post='731093']
Agreed. It's actually not my intent to do that to any great extent. I wouldn't mind make the car a bit less sensitive to it.
I'm going to string the car this week to recheck my settings so I have a baseline to adjust from.
That wouldn't be desirable at all. I'm still open minded on this idea.
I intend to lighten the rear, budget permitting as that is a big chunk of cast iron back there. But adding weight at the front would increase the polar moment and perhaps make the car more stable. Probably not what you meant though.
I also have replaced the stock proportioning valve with a tee. Rear brake lockup occured to me but I haven't checked to see if it is happenng though.
I tend to over analyze things I think. Sometimes I miss the obvious.
thanks;
Mike T
groot
Jul 18 2006, 11:34 AM
It may not manifest itself in rear lockup, but you may just decrease the amount of grip you have available for lateral acceleration (you know... the traction circle deal).
Do you have any rear steer issues? I'm asking because I did, beyond what's normally built into the 914 rear suspension. My right side rear outer suspension console was tearing away from the body. Caused some awful things to happen under heavy braking.
BTW... personally, I wouldn't go after antidive geometry... and certainly not to address your problem. It won't help your problem. Antidive (as you know) works by forcing your wheel to travel forward when it travels into jounce, creating a force that works against the braking forces. While it won't cause your suspension to bind if done correctly, it will not travel as freely as one would like it to during jounce events because it has to overcome that additional force.
Mike T
Jul 18 2006, 03:15 PM
I replaced the stock prop valve with a tee when I did the V8 swap on advice from this forum.
I could have rear steer issues. The PolyGraphite bushings on there now are 8 yrs. old and may be worn. I've seen some pictures here of worn ones.
I felt antidive may keep the back from rising under braking and keep the back from rolling. I imagined the car squatting level on hard braking instead of pitching forward. Not really sure what it does now as I'm in the car at the time...
Mike T
Demick
Jul 18 2006, 03:37 PM
Put in an adjustable brake porportioning device so that you can adjust the rear bias. Doing too much braking with the rear wheels will explain your symptoms.
You stated you replaced the stock prop valve with a T when you did the V8 swap, but you failed to state what brake upgrades you did. Please don't say you are running a stock brake system with those huge tires and a V8.
Demick
byndbad914
Jul 18 2006, 05:45 PM
QUOTE(groot @ Jul 18 2006, 10:34 AM)
on both accounts. I have an adjustable bias in my V8 car (I was 59.5% rear weight dist btw) and I was messing with the bias on the track. I added a "fair" amount to the rear to see the difference and damn near didn't make it thru turn 3 (a harder braking point on the track) at Willow Springs! Car was skating like a mofo, and wasn't locking up. You will just be loose as nuts when on the binders entering a turn with too much rear.
And the ass-end wanted to come around ALL the time on that car. Do you have an oversteer tendency? You mention no understeer, but didn't imply if that meant neutral, slight oversteer, or oversteer. Mine would OVERSTEER at any speed and the low polar moment is crazy. It is the only car I have ever spun and I have hung a few out there in full drifts before. Not the 914.
So I maxed out my swaybar and could get the car a little more neutral with throttle understeer when I had the balls to be on it and push out off the apex.
You need an adj bias valve and probably need a stiffer front setup. You state the front bar is about at 1/2 - does it help to max it? I would try that if you haven't. If the car gets better about sliding/drifting as opposed to snapping around, then you know you need bigger front T-bars (so you have adjustability in the bar again to tune to track conditions). Obviously if you start to push you don't need bigger bars. But if you don't plow, go bigger.
Don't bother with the anti-dive stuff - better to tune the car with springs and such. May want to consider coil-over fronts (RSR struts) to get higher spring rates. That is what I have. I was running 350 lb/in fronts and 450 rears before and the front was too soft - I maxed the Tarret bar as stated and have no rear bar. I am starting out 450/450 when the car is done and I have some 400s and 500s and 550s to tune the car at the track. Stiff setup, but with good tires (you have huge tires and soft compound at 25 btw so use the friction) it will work better IMO.
You autocross so I wouldn't expect you to go that stiff but you may need to be in the 300-350lb/in front to get that car to act right. Hard to say of course as it is all dynamic. I forget what the Tbars are equiv too, but maybe/probably not 350 lb/in.
Also, if you don't have one, get a tire temp gauge and set the camber correctly. You may not have enough rear camber for instance and tire temp gradients will tell you for sure. Doesn't matter what the value is frankly (I never pay attention to that) whether you tell me 1deg neg or 2deg neg. All I care is the tire temps are constant across the surface.
brant
Jul 18 2006, 05:52 PM
I'm also going to bet that and adjustable bias valve will make the car feel much better..
I ran modified brakes with an adjustable valve for years
at one point, I decided to switch to a "T" and see if I was giving up anything. I really don't think the rear wheels were locking on my car, but they must have been on the verge of it... because the first Day of trying the new set up, I spun the car in a braking zone at 65mph and went straight through the corner while facing backwards.
damage was luckily minimal.
I think I contributed to the problem by using a tiny bit of subconscious trail braking.
needless to say, I finished the weekend and put the dang adjustable valve back in before the next event.
65mph backwards into a ditch is not a fun thing
brant
Mike T
Jul 18 2006, 10:34 PM
Thank you all for replying. I'll try and answer all.
I measured the camber tonight and inspected the front Weltmiester Polygraphite bushings. I could pull the front bushings right off with little trouble. They didn't look excessively worn. What I did find was way more negetive camber on the drivers side than the passenger side. I certainly didn't set it up that way. I will have degree numbers tomorrow.
Nothing was loose when I dissasembled it. Don't know why there was so much difference right to left.
One thing to note is this car is originally from Texas and is completely lacking in any sort of rust at all. When I removed the backing plates years ago the original factory part numbers were still readable. Perfect hellhole. Perfect longs.There isn't even any surface rust on the control arms. Just factory paint. A rare find in the frozen Northeast.
Brakes: 19mm master cyl. Braided lines. Stock calipers, rotors. stock. Sorry but consider this. No Track use. No Steet use. Autocross only. SCCA autocross tends to be slower than PCA as I understand. These brakes are sufficicient for the task.
I have considered an adjustable bias valve.
No understeer. It's real good in that respect. Very responsive. Good controllability under hard acceleration. No power on oversteer to speak of.
Haven't maxxed the sway bar yet. Never been more than 1/2 way. It's as stiff as I've ever had it now. If I need to run it stiffer then I will consider going to 23mm t-bars.
the Sway-a-way website has a page where you can determine proper spring rates based on corner weights and motion ratios. I was in the general ballpark with my 22mm bars in front. When I had the V6 in the car I had 180lb springs and no particular tendancy to snap oversteer. After going to the V8 in 2004(added 130lbs in engine weight) I went to 250lb springs.
The car was completly different and was actually slower for a while. I made changes, tuned and eventually got faster thn ever but the snap oversteer is the last problem I can't get rid of.
Mike T
groot
Jul 19 2006, 06:13 AM
Adding antidive will not keep the rear from lifted, but it can keep the front from dipping. The way to control the rear lift is through increased rebound control in the rear dampers.
Mike T
Jul 19 2006, 06:58 AM
I understand that now. I'm learning a lot here. Thanks Groot.
I have camber numbers:
Left front -2.9° right front -1.25°
left rear -1.75° right rear -1.8°
-2.9° ?! WTF?
I'm sure I didn't set it like that. The rear numbers are just like I set them the last time I adjusted anything.
The front camber according to my records were set at -1.75° for both sides. It's like something shifted.
Could poorly installed roll cage bracing tweak the chassis bad enough to result in this? Warp it? I had some roll cage work done by a local circle track guy and he did a terrible job. I had a low front hoop and braces to the front shock towers done and he didn't put the bars where I wanted them.
Mike T
groot
Jul 19 2006, 08:15 AM
I'm pretty sure your Hoosiers don't want that much camber. There're are plenty of threads on alignment opinions.
Brett W
Jul 19 2006, 09:12 AM
Where is your ride height set right now, with you in the car? A severely lowered 914 will create all kinds of problems with the suspension geometry, although it looks much better.
Mike T
Jul 19 2006, 10:32 AM
Certainly not -3°.
If -1.75 is still too much I guess I need to do some homework.
I've spent the last 2 seasons just getting the engine/trans to work correctly I have neglected the rest. As you can tell.
The ride height is set so the control arms are just parallel to the ground, front and rear. In jounce they will go past parallel which is probably bad.
Mike T
brant
Jul 19 2006, 12:52 PM
Mike,
is the picture on page one under HARD acceleration.
its certainly nose up.
does it sit "nose down" when static?
I'm still betting that its the rear brake bias.
brant
Don Wohlfarth
Jul 19 2006, 01:38 PM
Too much rear brake, add in a little rear toe, might want to dail out a little of existing front toe, forget trail braking.
Get your car slowed down in a straight line, turn in, get on the power. There are very few turns in ax where you will benefit from trailbraking, instead concentrate on the other turns.
Trying to trailbrake a car with too much rear brake will put you in the weeds.
Mike T
Jul 19 2006, 03:44 PM
Brant- That was a slalom. 28 paces between cones. may have been at the end leading into a short straight to the finish lights so I may have been accelerating at that point.
Here is hard acceleration.
Mike T
Brett W
Jul 19 2006, 06:02 PM
raise the car up until the trailing arms are angle down slightly. Same goes for the front, but I would start with the reaer only and see how the car handles. Problem with the front when you lower it you increase the distance between the roll center and height of the CG, thus causing the car to roll more in a turn, not less like common sense would lead you to beleive.
Plus you have other problems.
Mike T
Jul 20 2006, 11:34 AM
QUOTE(brant @ Jul 19 2006, 10:52 AM)
Mike,
brant
Brant;
I just went through your Vintage Racer thread.
I am inspired.
Thanks;
Mike T
brant
Jul 20 2006, 01:50 PM
[Brant;
I am inspired.
Thanks;
Mike T
[/quote]
thats mighty kind of you sir!
Mike T
Jul 25 2006, 09:51 AM
Over the weekend I discovered some things that were not so good. Basically my chassis is twisted. I always thought it sat funny. I read Andy's "celette bench" thread and followed the links there. I got the same problem. Set ride height so the car looks right and the corner weights are way off. Set corner weights and it look crooked.
http://www.914world.com/bbs2/index.php?show...515&hl=bendNot sure what I'm going to do now.
Mike T
brant
Jul 25 2006, 10:58 AM
been there done that..
let it look crooked... (its only appearance)
and go with the correct corner balancing!
it will handle well still.
brant
Mike T
Jul 25 2006, 01:02 PM
QUOTE(brant @ Jul 25 2006, 08:58 AM)
brant
When the corner weights are right the twist of the chassis causes the front control arms to be at different angles. The passenger side control arm is parallel to the ground but the drivers side goes uphill from the balljoint to the torsion bar. The inner pivot points are nearly 1" different heights from the ground. Causes it to handle differently in right and left corners. I bet the roll center is migrating around like crazy.
I'd just bent it all back to where it belongs if i didn't have all the roll cage and front reinforcments welded in there already.
How about if I space the drivers side of the torsion subframe down untill everything is in the same plane again? I mean it's bent up now I'll just bring it back down where it belongs.
Mike T
brant
Jul 25 2006, 01:52 PM
ouch...
sounds more serious than mine was.
you sure you can't cut the cage and pull the chassis a little.
brant
Mike T
Jul 25 2006, 03:58 PM
That is a possibility. This whole thing started as a campaign to lighten the car more. I intend to do something similar to URY914's car. After I cut the bent nose off I'll have a better chance at straightening out what's bent. I'll be adding more tubing so replacing 2 at the same time won't be an issue.
For sure something has to be done.
Mike T
Mike T
Sep 8 2006, 08:57 AM
An update to the overhaul of my car.
http://www.914world.com/bbs2/index.php?showtopic=59712 I found one unusual thing; the drivers side threaded shock sleeve had slid down over the support lip on the Koni Red shock. When I installed the sleeves in 2004 they would not slide down over the lip even though there was a counterbore in the sleeve evidently for that purpose. They just rested on the lip. I figured I had the wrong part. I decided to use them anyway. The passenger sleeve was still resting on the lip.
So the perch on the drivers side was 3/8" lower than when I corner balanced the car. It's all I found that could account for the sudden unstable handling I was experiencing. The wedge I inadvertantly had dialed in made the car loose in one direction and tight in the other.
I deburred everything and now both sleeves are sitting properly on the shocks and are reinstalled on the car.
I expect to set the ride height, set the corner weights, toe, caster, camber next week.
My next AX is Sept 17th.
Mike T
