John
Jul 17 2006, 09:24 PM
I tried the search, but didn't find anything relevent.
What causes the speedometer needle to bounce until 30-40 MPH is reached?
The speedometer works nicely on the bench....
Is it a sticky cable (slip stick) or is it a worn out miter gear at the trans?
Could this be made worse by bad routing of the cable sheath? (A kink in the cable)
All opinions are welcome.
Thanks for looking.
Jul 17 2006, 09:27 PM
it's the cable. *every* 914 i have driven had that same issue.
as long as it get's smooth > 20mph, the cable is fine, otherwise, it's about to snap ...
Andy
newto914s
Jul 17 2006, 09:29 PM
good to know.
Thanks Andy
Toast
Jul 17 2006, 10:01 PM
Mine does the same thing. And my tach whips between 1 to 4500 until running steady.
Kinda musical looking.
Now.......when I wear my magnetic bracellet.........
Stieve
Jul 17 2006, 10:06 PM
Mine does the same thing with a NEW GEMO cable, I wish I knew as well...
pfierb
Jul 18 2006, 04:08 AM
Mine does the same thing but I eliminated about 80% of the needle shake by smoothing out the cable routing near the front fire wall forward of the pedals....above 35mph it's smooth as silk.
Stieve
Jul 18 2006, 10:10 AM
Ah! George just informed me to NOT route it throught but above the engine mounting bar. I will let you know.
Jul 18 2006, 12:17 PM
QUOTE(Stieve @ Jul 18 2006, 09:10 AM)
the hole in the engine mount bar is for the clutch cable! route the speedo cable above the bar and zip-tie the two together close to the clutch wheel to prevent the speedo cable from dragging on the ground ...
Andy
