QUOTE(donj44 @ Jul 19 2006, 05:50 AM)
i got the car 5 years ago its been in my garageso i decided to get it running or sell it yes it is a stock injection
Great!
You've got a big project ahead of you if you're serious about getting the car running. It sounds like you are at crossroads, and may just sell the car. To get it running for daily use will involve rebuilding much more than just the fuel system if the car has been sitting for five years. You didn't specify when the car last ran, so maybe it sat in someone else's garage for five years before you got it.
Before you do anything you should check for rust in the deepest pockets of the engine compartment, especially near the battery tray. Then check the suspension mounts for rust. If you're willing, remove the rocker panels (the long panels that go along each side of the car) and check for rust there too. Rust problems can be fixed, but we can discuss that later.
Point being, the fuel tank should be removed and professionally cleaned, inspected, sealed. All fuel lines should be replaced (and there are some beneath the tank that can be replaced rather easily when the tank is out).
Do the brakes work? I'd replace all four of the soft lines and if they're not working then you might find yourself in need of a new master cylinder and having to rebuild all four brake calipers.
The motor's various oil seals are probably rotten now, so oil will likely leak from the pushrod tube seals, valve covers, main and fan seals, etc. You should also adjust the valves, change the oil (now!), set the ignition point's dwell, check/set timing, etc
Stock D-Jet fuel injection works well on a car that's driven regularly, but often needs a lot of attention on cars that have sat. Along with replacing all the fuel lines you'll need to also replace the intake runner seals that connect the plenum to the intake manifolds. The fuel injector seals are also going to need replacing, as will the various vacuum hoses. There's a chance that the injectors themselves will need cleaning/rebuilding/replacing too.
Sorry if this isn't encouraging, but I'm just trying to give you a realistic idea of what you're getting yourself into. A lot of us have gone through this list many times, and oddly enough really enjoy bringing these cars back from the dead.
We haven't posted many formal tech articles on this site yet, so I'd recommend looking over the various articles at Pelican Parts to get an idea of what's involved in fixing some of what's going to be wrong with your car -
http://www.pelicanparts.com/914/914world.htm You can do it to, but you'll need a lot of patience, a little money (or a LOT of money if you have someone else do this stuff for you) and you'll need to lean on this club a bunch.
Good luck!
