QUOTE(crash914 @ Jul 19 2006, 07:26 AM)
Yarin, so what did you find out was the problem?
how is it running now?
Hey Herb,
I don't even know where to start, a series of things that led me in a loop.
After discovering and solving a stuck open injector, stuck closed injector and had all the injectors cleaned again I found my injector bank problem. There was a flux bridge on the active flyback circuity of one channel. The weird part was the signal looked perfect on a scope using the stim, but when loaded the output was bad. So that was one issue. I chased that issue for at least two months.
The turning point came one day when my brother was helping me out. I still couldn't get the idle to stabilize, it run cycle up and down from 900-1200rpm. He suggested taking the car out for a drive, so i bit the bullet and let it loose. Ran like crap for the first two minutes, bucking, sputtering, then after two minutes of either burning something in or AUTOTUNE it magically smoothed itself out. I did a minimal amount of tuning since I used someone else's tables.
After all that I ahd a bunch of non-MS issues to solve, brakes, loose shifter rod, loose rocker/valve bolt, etc etc.. small stuff u know.
I can finally proudly say that the car is running reliably. I haven't setup TPS-accel and spark is still handled by the dizzy advance. However it starts up all the time, runs almost perfectly! Car finally shifts nice, i think its pretty much ready for autox!
I lost hope a times and got busy with other stuff like starting my MBA and whatnot. But I stuck through it and have something to show for it. I hope to put up a site sometime soon with a build plan, material list, how to and all of that stuff.
Thanks for your help!
