stephen7
Jul 19 2006, 09:43 PM
Hey guys
I tried to use an easy-out but this broken heat exchanger stud is stuck. Since the head is aluminum and the stud is (?) some hardened metal - will this work? I took the fuel line off and ran the engine until it stopped so hopefully I won't blow myself up in the process
what do you think?
thanks
bd1308
Jul 19 2006, 09:58 PM
ok
heres what you do
1)grab welder
2)grab nut that fits and/or screws onto stud
3)weld nut to stud
4)get LONG and STRONG wrench
5)Heat stud area up at head, turn wrench
after a few times and possible snapped off stud, you should get it out
b
Trekkor
Jul 19 2006, 10:39 PM
Yes, the heat from the weld should do it
KT
stephen7
Jul 20 2006, 10:46 PM
I snapped off the easy out today after using the torch method. Next is the welding. wish me luck.
McMark
Jul 21 2006, 02:23 AM
Eeek, broken easy outs are no fun. If nothing else works, take it a machine shop that can use an EDM to get it out. When you're welding, don't arc to the aluminum.
