I'm trying to get my Webers dialed in, and I used to have a good, baseline instruction sheet to start the process. But, it's nowhere to be found. Anyone have a good process documented for setting up the Webers on my 6?
Things that I remember included: disconnecting the carbs to set idle independently, start all of the idle mixture screws at the same number of turns out (1.5?), establish a baseline using the unisyn for the air correction jets, then equalize all each barrel, etc.
It's been a while since I did this, so I'm looking for the tried and true method. I've got the timing all dialed in, but I'm getting lots of popping an load-up from the carbs during my break-in period.
Thanks,
Dion
