QUOTE(HeloMech @ Jul 20 2006, 11:21 AM)
QUOTE(Dr Evil @ Jul 20 2006, 11:07 AM)
What, no one is gonna mention the filter sock inside the tank?
Huh? doh... can I get to that? or is that a draining and pulling the tank type of thing?
Thanks!!
Nah, don't mess with it
yet. Do the easy stuff first and the fuel filter is pretty easy.
Messing with the sock in the gas tank can lead to draining the tank
which could lead to removing the tank
which could lead to etching and refinishing the tank interior
which would lead to repainting the outside of the tank
which could lead to a late model fuel pump relocation
which could lead to adding a weltmeister swaybar "while you're in there"
which could lead to installing KONIs all around
which leads to new rear springs and tbars
which leads to numbers for AXing
which leads to converting to a six
which leads to flaring the car,
which leads to....
So then $15,000 later you've successfully troubleshot your fuel system problem.
You get the idea. You're on a precipice.
Later,
Kevin
