QUOTE(Joe Ricard @ Jul 20 2006, 10:33 AM)
Had to replace rear wheel bearing. So I swapped out the whole trailing arm from the stripper.
Now I have bolts vs. studs. YUCK not to mention the Centerline wheels need a spacer and I have nuts not bolts. So long studs are the order of the day.
Press in of course, However need to remove the thread so I can press in the 14 x 1.5 mm studs.
Anybody got one that I can borrow. Never thought it would be so hard to find. tool depots and warehouses either don't carry them or they are huge.
I have a few metric reamers but can't find them since we just moved Joe. I'll keep looking. No promises I'll find them.
Meanwhile:
If you have any buddies working in a machine shop near you, just get them to borrow the size you need. Two different types for the straight hole the press in stud hole will need. Hand reamer, which you use with a tap handle to turn the reamer with and high speed reamer which you just stick in a drill motor. Use oil with either. Keep it straight.
MikeCool
Oakfield TN
