KaptKaos
Jul 20 2006, 02:40 PM
Several weeks ago I replaced all of the bushings in my shift linkage. It took me a while to get the shifter adjusted, but I thought I had it pretty good.
So I was using the car for a few weeks, and occasionally I found it hard to shift into first. There didn't seem to be rhyme or reason to it. So I adjusted the shifter again. All I did was rotate the shaft a spline or two and then tightened it back down.
Shifting improved alot, I think I got it a little better. I still occasionally have issues shifting into 1st and now sometimes have a problem hitting 3rd, but generally only on a downshift.
So the question is: Is there something else back there that could be affecting the geometry of my linkage dynamically? A bad mount or something maybe that is causing the tranny to wiggle around and make my shifting inconsistant?
OR, do I just need to go back and adjust my shifter again?
Thanks in advance!
Joe Bob
Jul 20 2006, 02:50 PM
Have you checked the shift bar and the cone screws?
Joe Ricard
Jul 20 2006, 03:07 PM
Any kinda movement with regard to engine and or transmission will affect the way the shift rod actuates the selector in the shift console.
whole car twisting can also affect this.
and 1 spline can make a huge difference. unfortunately 1 spine adjustments are pretty freaking tough.
mikelsr
Jul 20 2006, 03:19 PM
QUOTE((*)(*) @ Jul 20 2006, 03:50 PM)
I had a similar problem and it was the cone screws.
KaptKaos
Jul 20 2006, 03:54 PM
I'll check the set screws. They are new and came with the new set of bushings.
Dr Evil
Jul 20 2006, 11:34 PM
Check your engine (rubber ones) and tranny mounts if all the usual suspects look to be ok.
Stieve
Jul 21 2006, 02:13 AM
I have a simular problem, but the gears engage, just the shifter seems different, I guess I can put it out of gear and reset the shifter.
Here is a weird one though, my Volt gauge discharges like grounding out in reverse. WHY!
Dr Evil
Jul 21 2006, 09:40 AM
Check the reverse circuit from the reverse switch to the board and beyond. Where is your volt meter hooked into?
Aaron Cox
Jul 21 2006, 09:49 AM
QUOTE(Dr Evil @ Jul 20 2006, 10:34 PM)
especcially if on downshifting... get some new mounts, and tighten all your cone screws.
we can look at it tomorrow
2-OH!
Jul 21 2006, 09:58 AM
Clutch adjustment...1st and Reverse are the first to show up if your clutch is not working perfectly...
2-OH!
Stieve
Jul 21 2006, 10:49 AM
Volt gauge is wired directly to console wire plugs for it(73)
pfierb
Jul 21 2006, 10:57 AM
QUOTE(Stieve @ Jul 21 2006, 04:13 AM)
Could be that your backup lights are coming on and making the volt meter needle move downward.
Stieve
Jul 21 2006, 11:10 AM
they work, just shocked me how it just dropped down when doing it. ALso What do you think about the shifter adjustment?
