Michael J
Jul 21 2006, 10:40 PM
Many instructions talk about using a brass punch. I have not been able to find one at any of the parts stores. I looked at the hardware store and found brass bolts that look like they will work if not too hard. The bolts are grade 8 brass. Is this softer than the steel shafts and gears?
davep
Jul 22 2006, 06:15 AM
I believe that should work okay.
Or you could visit a machine shop and see if they can help. I'm always making my own tools.
r_towle
Jul 22 2006, 09:11 AM
I may be wrong here...
But I dont think you could possibly get Grade 8 brass anything.
The bolts are steel coated with brass, Grade 8 is suspension grade bolts..they are steel, and hardened.
Look for a good hobby shor or craft store, or steel shop..they should have brass rod..cut to suit your needs.
Rich
GWN7
Jul 22 2006, 09:25 AM
http://da.harborfreight.com/cpisearch/web/...h&Submit=GoBrass is susgested to use as it is softer than the metal it's to be struck against. That way you lessen the chance of damaging the object.
Michael J
Jul 22 2006, 10:21 AM
I understand the point of using brass I just was surprised that the auto parts guys didn't have anything-----well maybe I shouldn't have been all that surprised.
The link to harbor freight is good and I got to thinking about going to the local machine shop and have them cut me a piece.
Thanks guys.
So.Cal.914
Jul 22 2006, 12:15 PM
Or go to your local auto repair or motorcycle shop, Snap-on, Mac or another
will stop at least once a month. But you can get a number for them and find out
where they will be. They should have just what you want.
McMark
Jul 22 2006, 12:25 PM
I know NAPA stores can get them.
mightyohm
Jul 22 2006, 02:50 PM
Sears has a brass punch set, I use it quite a bit. I don't think it was that expensive.
