I have a question about matching ring and pinion gears. It is my understanding that the ring and pinion are each etched with the same numbers from the factory that indicate they match. What is the meaning of these numbers, exactly, apart from their aforementioned usage? How are they derived? Are they arbitrary (except that they match) or are they directly related to measurements of the two units? I want to know how close the numbers have to be in order to consider the gears "close enough" for use in the same trans. I have a pinion gear with the number 215 on it. I also have a ring gear that has 195 on it. So, is it the case that these units are more compatible than units with 215 and 800? Just wondering. I have everything needed to put together a nice little trans if I can use these two parts together with impunity.
Thanks!!!!
