Hello, whenever my '74 is switched to the on position, whether running or not, the oil pressure idiot light blinks on and off with the directional relay...it does this regardless of whether the wire is connected to the sender on the engine, so i know the bulb is grounding out where it shouldn't....
here are some pictures. The black wire with green and whitish stripe goes from the idiot light to the directional relay, and there are two brown wires which I assume are grounds....is this correct? I don't see the idiot light wiring going through the flasher relay on the PP electrical diagrams...
Any ideas would be great!
