QUOTE(Headrage @ Jul 23 2006, 04:22 PM)
QUOTE(Jeroen @ Jul 23 2006, 04:18 PM)
struts are usually filled with anti-freeze or something similar before the inserts are put in
Really?
This isn't anti-freeze but oil. I'm going to pull it and have a better look.
The strut itself is filled with a coolant. Sometimes this is oil, like mineral oil or other lightweight oil. Sometimes it is filled with antifreeze. It is intended to assist with the transfer of heat.
So, as others have said, if it is the koni strut insert that is bad. If it is the loaded strut, not so bad.
