QUOTE(nycchef @ Jul 23 2006, 06:03 PM)
why did you relocate your pump?
Andy
thanks i didn't realize about the pressure. relocated the pump because of vapor lock. center tunnel lines are stock are they o.k.
interesting. i have never had any problems with vapor lock. is this a race car?
anyways, the best location (IMHO) for the front fuelpump is under the tank. there's plenty of room for a filter there too, plus, the fuel lines are right there.
you should consider putting the filter under the tank, between tank and pump.
as for the stock plastic lines, make damm sure they're in good condition. 30psi makes for a nice gas-o-line sprinkler inside your car ...
Andy
