QUOTE(Joe Sharp @ Jul 24 2006, 11:01 AM)
Robert: You should have driven it here first. I need a better discription of the noise.
:PERMAGRIN: Joe
I was thinking about running over to your place yesterday, then that freak rainstorm thing hit for a while. I drove it around the block a few times, out on warner, etc. Seemed fine. It drove very nicely this morning all the way up bolsa chica until about Lampson it started acting up. a little bucking if the rpms were down around 2k.. or so in like 3-4 gears. Made it to work without any real incident. Stopped at the gate, then pulled out of there and ran fine. Then about 2 blocks later... blah... just died. The sound it made when I tried to run it up over 3 grand.. it was just weird. Almost like the sound of an arc welder... but not... lol. I really don't know how to explain it. It's all new plugs, wires, cap, rotor, points, condensor and battery. I replaced vacuum lines, fixed wires to the coil and head temp sensor. It's just run GREAT for these past couple of days. I'm guessing this starter thing and the way it started running are coincidental.. not related.
It will probably get left here at work today after work. Then maybe come up tonight and work on the grounds, try jumping the starter solenoid, etc. I would rather get it running and on the road heading home without all the traffic... incase I have to bust out the AAA card.
Joe... You're home? come up and fix it ! ! !
Support your troops! lol.
Robert
