QUOTE(Joe Owensby @ Jul 24 2006, 07:11 PM)
Vapor lock will usually occur after the car is hot, say after driving some distance,(usually on a very hot day), and then maybe the car is either stopped at a traffic light and the engine is idling, or maybe the car is turned off and then you try to start it after a short time. What happens is that the fuel is not running through the fuel pump fast enough to keep it cool, and then the fuel vaporizes, and the pump can not pump vapor. After everything cools down enough, the gas vapor condenses back into liquid, and the pump works again. This happens most on the stock fuel pump location because it is under the engine shelf where heat collects. Joe O.
Thanks Joe, that's awesome. That really hits home with what I'm experiencing. I've driven it locally several times with no issues. About a mile or so. This trip to work this morning was it's first "long" trip.
As for the starter, I think there is a relay added to it. On a STOCK starter, there's a solenoid ON the starter and that's it, right? Mine has the starter, with the thing on the starter, then on the sheetmetal to the left of the starter is another thing. I assumed that was the solenoid but after looking at this paperwork in the folder from the car, I believe it's a relay.
I'm going to do a search on relocating the fuel pump and try that out to see if it clears up the problem.
Thanks again for the info.
Robert
