QUOTE(lapuwali @ Jul 25 2006, 08:54 AM)
Actually, I'm hoping to add no more than 100-150lbs total to my -6 conversion. The engine (a 2.7, so Mg-cased) is roughly 75-100lbs more, and the tank, lines, and the extra 6 quarts of oil should add another 50 over the T4. The mount (Maddog's clone of the RJ mount) will weigh substantially less than the shift-shifter cast iron bar; and the Bursch -6 headers are lighter than the stock -4 HEs, so that's some weight dropped. Since I've already dropped the early -4 car to under 1900lbs, I'm hoping for a 2000lb -6.
its doable.
and I'll bet you do it!
but it takes someone like you that is paying attention to detail and conscious of the challenge.
many -6 race cars come out heavy until they cut away all of the chassis and go with the semi-tube frame approach.
but with attention to detail its very doable.
I think JP is weighing in at 1840lbs or something near that.
brant
