QUOTE(Cap'n Krusty @ Jul 25 2006, 09:17 AM)
By design, Helicoils, Time Serts, and other thread repair products use a thread slightly larger than the bolt or other male threaded part that goes in the hole. The threads on most are "timed", that is they're synchronised with the threads they repair. They CANNOT be a "left hand" thread if the parent metal has conventional threads. Your problem is something other than a bad Helicoil. The Cap'n
Yes.....you are right. It is not a helicoil...it is an insert....and the threads are the same direction. Could overtightening the plug possibly stripped the insert outher threads or the head again??? SH$T!!! I hope not!!!
Mike
