I received my innovate #3769 LC-1 and O2 sensor and am preparing to install it. The box did not come with instructions. I went to the innovate site for a manual http://www.innovatemotorsports.com/support...LC-1_Manual.pdf and was worried to see that the read out was a 1 with plus or minus. Is this not a narrow band monitor/sensor?
How can I confirm that this will provide me with the true a/f ratio for tunning?
If this is the correct unit, any instructions/suggestions on how to hook up the unit?
I have planned to place the sensor/bung after the 4 to 2 to 1 header connection in my Bursch exhaust system. I was planning to have in cockpit monitoring. What is the best route to run the wires? My other sensor wires run through the central channel through a brake line conduit. These wires would not fit through the conduit. Should the computer connectors be in the cockpit? What is a reliable fused 12v source for the setup?
THanks,
Larry
