QUOTE(70Sixter @ Jul 27 2006, 08:59 AM)
QUOTE(Cap'n Krusty @ Jul 26 2006, 01:14 PM)
Depends on your definition of "early". True "early" 900 series cars, 1964-1968, are REALLY different, and use 2 bearings. Later ones differ in CV diameter and configuration, but may fit the splines.
The Cap'n
Cap'n is correct as usual. The "early" lobro halfshafts had two universal joints per side. CV joints replaced them in 69 I think.
Actually, CV jopints appeared in 67, IIRC. Retrofit kits with inner and outer stub axles and a CV joint halfshaft were in the kit. Many cars had them installed one side at a time, so you would see them in the shop with one of each. The pre 1969 outer shafts were about 10" long and had a small number od large ssquare cut splines, much like a VW bug or bus. The Cap'n
