QUOTE(r_towle @ Jul 31 2006, 05:41 PM)
Its really pretty simple as far as the parts go.
But to explain a bit.
Remove your old engine/tranny
once its out, remove the tranny..you can re-use the pressure plate and clutch disck, but now is a great time to replace them if you have any doubts.
Now, on the front of the motor, the fan shroud needs to come off (Its easier to see everything this way)
you need to unbolt the motor mount bar from the motor, this bar only works with the tail shifter.
Once the fan shorud is off, and you have the new motor mounts, and brackets in hand, you will see the holes in the case, on either side of the oil pump...this is where the motor mount brakets go.
the brakets bolt to the case, use locktight on these bolts,,,they are very hard to get to later...
On the bracket goes the rubber motor mounts, these should be new mounts...
On the rubber mounts goes the motor bar...
now re-fit the fan shroud.
Now, the shifter.
What you need for this is all of the shifter linkage, front to back including the actual shifter itself, this is all a bit different...
So, remove all the shifter linkage from the tail shifter, and inside the cabin, remove the shifter.
now, the motor is still out of the car...
on the firewall, there is a bushing that the old shifter rod went through...get a screw driver and pry it out...its not easy...but it will bend if you work at it...try to bend the bushing and not the surrounding metal...
The new bushing is really hard to put in..I boil it, in really hot water..it makes the plastic a bit more bendy, but only for a few miutes...so you may need gloves for this...
In any event... after you get the new bushing installed, you will probably hate your car and hate the idea of changing this to a side shifter...but that is really the worst part...that bushing...
The rest is simple...with the engine still removed, slide the shifter bar into the cabin, the short bar...one end of it will have a hold in it..that end faces the motor..
you can install the shifter now...it makes it easier to get everthing together in the following steps...
Now, install the new transmission on the motor..get all the muffler parts all bolts back in.
Re-install the motor and tranny together.
Once that is done, you take the rear shifter bar, and with the car raised up in the rear, you can feed the shifter bar through the motor mount bar from the front of the car, ind slide it into the shifter housing on the tranny.
The hard part is getting the front bar into the rear bar...i use two people here...
One person is pushing the shifter inside the car so that the inner bar is pushing back rearwards...the second person is under the car, pushing the rear bar forward...they slip together ok, if they are clean...
there is an allen screw that only fits in one spot...install that when it all lines up...
In the rear of the bar...you need to install the cup pivot assembly...
this also has an allen screw that fits in only one spot...so tap and twist till it all lines up...then screw it in..
NOTE..these allen screws tend to back out over time...so more locktight here is the right thing to do...
so, youare almost done...
You just need to align your shifter so you can get to all the shift gates...
I tend to do this, drive , then do it some more...
bring a set of vise grips, and a 13mm socket on an extension with you while you drive..
Between the seats, near the firewall there is a small cover on top of the tunnel...remove it...
I grab the shifter bar with the vise grips to hold it still...then loosen the 13mm nut that attaches the shifter to the bar..with the shifter handle and the vise grips, you can twist, and slide in and out on the bar till it all works perfect..then drive, do it again,,till you can get to every gear..
Good luck
Rich
Thank Rich
I’m gonna print this and it would be of use when I’ll do the job, one thing though it is not a simple conversion cause I didn’t have the old setup and I don't know what exactly I do have here (some of the stuff is improvised).
where would you buy the bushings and rubber seals and the mounts?
dror
