QUOTE(seanery @ Jul 27 2006, 11:45 AM)
I need some help here. I have had the hiccups for 3 days. It came about when I was coughing, I got sick 4 days ago. The hiccups are very painful now, and happen at 4 second intervals.
I need to get rid of them, for good.
Please, none of the quick fixes that your grandma told ya, I need to know from the docs and whatnot what really works.
My shoulders, neck, back and throat are in pretty bad pain now because of these damn things.
thanks in advance
This is an explaination from my Aunt who is a pediatrition and has treated a number of kids with chronic hiccups:
Hiccups are caused by the fact that the protective flap that covers the esophagus/windpipe is dislodged from its normal position. Hiccups are the bodies attempt to put the skin-flab back in the right place.
One of the most effective ways to "help" the body set things right is to do something that causes rapid "dry swallowing".
For instance, Wet your finger and dip it in sugar and then suck on your finger and swallow as many time and in as short succession as you possibly can. The sugar is there to make you salivate so that it is easier to swallow in short succession.
The repeated constriction of the throat accompanied by the movement of the larnax when swallowing is one of the best ways to help cure the CAUSE of hiccups.
Headrange, this is probably why your "eat a lemon trick" works.. It forces you to salivate and swallow hard.
This, by the way, has ALWAYS worked for me.. But you have to force yourself to swallow even when you think you can't.
Hope it helps
Doug
