QUOTE(Dave_Darling @ Jul 27 2006, 05:49 PM)
Having toe-out in the rears will make the car want to oversteer. When the rear gets a slip angle, it will keep trying to pull to that side. This is a "positive feedback" situation, and can get out of hand pretty easily. Toe-out will tend to make the tires wear more quickly on their inner edges, at least in conjunction with negative camber.
I would think it would be pretty tough to run out of adjustment room before you get to toe-in, though. Is your tub tweaked, or are the trailing arms beat to hell?
--DD
I don't know!! I am not even sure how bad it is!! I wouldn't be surprised if the tub
is bent, although there does not seem to be any visible damage to the car.
I am learning so much this time around!!! I had a car in the 70's, but never
learned half of what I have learned in the past two months! I'll find out more
tomorrow about the adjustments. I have to talk with the alignment shop anyway.
They lost one of my center caps while changing the tires!
Thanks,
Jeff
