ChrisReale: Yes I am. The WEB 73 is the main reason for going to the MS. Its supposed to be stock FI compatible, but I've found that my setup does not provide sufficient adjustment across the operating temp range. Ned something more programmable.
Herb: Shame on you! You're lettin a Teener take back seat to a bimmer? Did you get to the installation? I'm planning on locating the ECU under passenger seat - hope it fits.
Thanks Mueller. Is yours up and running? Like to here more about it.
Dave: I was hoping to get your files. Do you know what temp values you used from the sensors when creating them (a min of 3 vals req'd)? The reason I ask is that I've noticed identical stock parts output variations in signal. SO I'd like to compare your sensor values to my stock sensors and make sure they match.
Also Dave, you mention in you Files URL that someone could use your files with a stock programmed CPU (& 6-ohm/10watt res) - did I understand that correctly, or do I need to bribe, plead, beg you to program mine?
If I were to send you the $$$ + shipping cost, would you be willing to pickup another set of the 6-ohm/10-watt resistors for me? Local radioshack don't have em.
Thanks all,
