Went to the doctor this morning because my right hand ring finger has be stiff, tender and sticks when I try to flex it. It's been like this for over a week. I'm thinking I'm too young for arthritis and I don't remember jamming my finger
Doctor says "You have trigger finger. I've seen lots of people with this since the weather got so hot."
So I ask the doctor "Is this a temperature/weather related ailment?"
And the doctor says "No one really knows the exact cause of it."
Then he proceeded to give me a cortisone shot in the palm of my hand under my tender knuckle. In case you were wondering it FUCHING HURT! And tells meto come back in 2 weeks
Beware of the mysterious trigger finger affliction!
Description
Trigger finger, also known as stenosing tenosynovitis, varies depending on the severity of the condition. Treatment ranges from rest to medications to surgery.
A trigger finger is a common problem that causes pain and catching. Tendons that help bend the fingers and thumb slide through a snug tunnel. Irritation as the tendons slip into the tunnel can cause the opening of the tunnel to become smaller, or the tendon to thicken so that it can't easily pass through the tunnel. As you try to straighten the finger, the tendon becomes momentarily stuck at the mouth of the tunnel then pops as the tendon slips past the tight area. This can cause pain and catching as you try to move the finger. Your doctor can diagnose the problem by talking with you and examining your hand. No X-rays or other testing are usually needed.
Risk Factors/Prevention
It isn't usually known what causes the problem. Trigger fingers are more common in women than men. They occur most frequently in people who are between the ages of 40 to 60 years. Trigger fingers are more common in people with certain medical problems such as diabetes and rheumatoid arthritis.
Symptoms
Symptoms usually start without any injury. You may feel pain in the palm, sometimes along with swelling or a small lump. You may feel the catching or popping sensation in the finger or thumb joints. Stiffness and catching tend to be worse after inactivity, such as when you wake in the morning, but will often loosen up with movement. When it breaks free, it may feel like the finger joint is dislocating. In severe cases the finger may become stuck in a bent position so that it can't be straightened even with the help of other fingers. One or more fingers can be involved.
