My 75 914 1.8 stock won't stay idling. I am not the best mechanic, so let me describe the problem and how it happened and hopefully I can get a recommendation.
The car has original 57K miles on it. I drove to Seattle from Spokane (about 4 hrs) and it drove fine. When I went to fire it up the next morning, it fired up fine but wouldn't idle if I took my foot off the gas pedal. I discovered that the seal on the oil filler cap had gotten loose and was not sealing. Once I tucked the seal back in , voila, everything was fine and it idled just fine. I drove back to Spokane and when I got home, I noticed that there was oil burning all over the top of the motor when I turned it off. I fired it up again and it would not idle again once I took the foot off the gas.
The oil sprayed more towards the insulation on the back of the wall. I am not sure where the oil is coming from. Maybe the black box the filler tube goes into. But if the gasket was blown out, do I have a major problem?
Any advice is very much appreciated.
